-   -   Keyless entry reprogramming on 2000 Montana (https://www.pontiactalk.com/forum/montana-22/keyless-entry-reprogramming-2000-montana-129/)
driver 2000 Jan 18, 2006 10:58 PM
I wanted to know how I can reprogram the keyless entry remote for my 2000 montana . Does any one know how. ....
Patrick Feb 3, 2006 04:21 PM
RE: Keyless entry reprogramming on 2000 Montana
i know that with many newer vehicles,it takes a tool that is very expensive.
air3bwm Oct 26, 2006 12:31 PM
This is from the 2002 service manual, but it may work. note: BCM means body control module.
1. Remove the key from the ignition.
2. Remove the BCM PRGRM fuse.
3. Close all of the doors.
4. Insert the key into the ignition.
5. Turn the ignition to ACC.
The BCM will perform the following:
Flash the seat belt indicator 2, 3, or 4 times
Chime 2, 3, or 4 times.
6. Turn the ignition to OFF, and then back to ACC within one second.
7. Open and then close any door.
8. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
note: After approx 7 seconds the BCM will chime once to confirm that synchronization has been completed. After 14 seconds the BCM will chime a second time to confirm that the programing has been completed.
9. Repeat for additional transmitters.
10. Remove the ignition key.
11. Install the BCM PRGRM fuse.
12. Operate the transmitters to verify correct system operation.
