-   -   Montana windshield wiper stuck up (https://www.pontiactalk.com/forum/montana-22/montana-windshield-wiper-stuck-up-521/)
basmith Dec 6, 2006 11:00 PM
1999 Montana. When we turn off the windshield wipers they end up straight up and down on the windshield.
When turned off, they hesitate on the bottom and then before they would normally go below the hood to the off position they now go up and stop.
Revredneck Feb 23, 2007 09:51 PM
RE: Montana windshield wiper stuck up
There's a funny looking mechanism on the wiper motor that lets the wipers park. I think it's called a parking cam. You should have a look at that thing. There was a recall on them in the late '90s. You might check on that, too.
salcock Apr 10, 2007 09:53 PM
i had a simular problem with my wipers and found out that the parking plate which i call it went out of sequance due to the bolt holding down the plate came loose disconnect the main arm on the motor and run the wipers so it could go back to its origanal position and manualy bring the wipers down to the bottom of the window reconect the arm and it should be ok
p.s i had to do this a couple of times before i got it right
sleder Jun 7, 2007 12:26 PM
Yes you are right its called a wipper park arm while your looking at it there should be atab sticking up from were the park arm is mountedthat actually catchs the rotating park arm to park it this usally gets bent down this happens in the winter if they were frozen at one time.
