front brakes
ORIGINAL: pontiacnoob
How do you change front brakes on a 1990 Autopartswarehouse Pontiac Solstice? tnx..
___________________
pontiacnoob413468465
___________________
Remove the wheels; loosen the caliper bolts; use C clamp on rear brake pad to retract piston then remove rear pad. good luck
I think you are talking about brake pads.. here is the method.
here are the list of tools which are required
Disposable mechanic's gloves
Jack for up the car
Lug wrench
C-clamp
Wrench
Turkey baster
Plastic tie, bungee cord or piece of string
you can follow this site to see the full method because its too lengthy so I can't write here.
Gud Luck
edmunds.com/how-to/how-to-change-your-brake-pads.html
Jack for up the car
Lug wrench
C-clamp
Wrench
Turkey baster
Gud Luck
pontiac35hp
Jun 18, 2011 01:42 AM
