front brakes
How do you change front brakes on a 1990 Pontiac Solstice? tnx..
___________________ pontiacnoob413468465 |
RE: front brakes
ORIGINAL: pontiacnoob How do you change front brakes on a 1990 Autopartswarehouse Pontiac Solstice? tnx.. ___________________ pontiacnoob413468465 Remove the wheels; loosen the caliper bolts; use C clamp on rear brake pad to retract piston then remove rear pad. good luck |
RE: front brakes
tnx so much..need more info
nice posts..........
I think you are talking about brake pads.. here is the method.
here are the list of tools which are required Disposable mechanic's gloves Jack for up the car Lug wrench C-clamp Wrench Turkey baster Plastic tie, bungee cord or piece of string you can follow this site to see the full method because its too lengthy so I can't write here. Gud Luck edmunds.com/how-to/how-to-change-your-brake-pads.html |
| All times are GMT -5. The time now is 08:55 AM. |
