-   -   99 Sunfire problem (https://www.pontiactalk.com/forum/sunfire-1995-2005-14/99-sunfire-problem-1133/)
javisam Oct 3, 2007 09:22 PM
99 Sunfire problem
Hi, I am having the following problem with my 1999 Pontiac Sunfire (2.2L, automatic):
When I try to go at constant speed or accelerate very slowly the car backfires…. When I accelerate more firmly (about 50% of the accelerator range or higher) or leave the accelerator alone so the car can go with its inertia, the problem goes away…. when i leave the car on parking or neutral or in a gear without moving it works perfectly....
I have some problems with the muffler that I will be taking care in the following weeks, but if the problem is that will it go away when I accelerate harder or stop accelerating??? (I mean, can I rule out a muffler problem based on the conditions of the problem??)…
Somebody told me it can be the transmission or the fuel pump, but the problem also happens when I drive on 1st, will that rule out transmission issues or it might still be present even when it’s driving only in first gear???
About once a month the cart doesn’t want to start and only does it when I push the gas, does that indicate something related to the fuel pump????
I changed the spark plugs, the wire set, the fuel filter, air filter and cleaned the injectors…
I know it will be almost impossible to locate the problem with an email, but I want to know if there are tricks or tests I can try to rule out some areas of the engine instead of changing parts that doesn't need to be change (the muffler needs to be changed but for example the fuel pump might be ok)...
Any help will we most welcome….
Thanks....
SunfirePerformance Oct 5, 2007 06:10 PM
RE: 99 Sunfire problem
It could be a number of things. If its just backfiring at cruising speed. It could be emissions control system; a vacuum leak around the fuel injectors, intake manifold or vacuum hoses; and last but not lease burned valves or incorrect timing. But here's another question I need to ask you. Does it stall, miss, or lack power?
javisam Oct 7, 2007 02:47 PM
I car passed the ny inspection two weeks ago, can i rule out the emissions???
the car doesn't stalls or misses power, actually it keeps the same speed... if i accelerate the problem goes away...
thanks....
SunfirePerformance Nov 13, 2007 12:41 PM
Ok.(Sorry so late to respond) Well. Check the fuel system pressure. You can get kits at autoparts stores, it will test the fuel system pressure at the injectors, the fuel filter and in between. Another suggestion is to get a Haynes Repair manual. It helps and will give you some better hints.
