Overheating and leaking yellow liquid
I think I know what maybe wrong with my car but I would prefer suggestions ...
This started as of today, my car has been overheating quickly, even when it idols you can see the guage move up slowly. Also, when I turned the car off, I noticed that a yellow liquid was leaking out of my car near my tire on the front end driver side. |
RE: Overheating and leaking yellow liquid
Low coolant level. Check the radiator drain plug on the bottom left hand side. It should be a green plug. It should be screwed in all the way. Then check the cooling system pressure. You can get a kit to check the pressure. Hope this helps. Tell me more about this problem?
| All times are GMT -5. The time now is 05:59 AM. |
