-   -   A REAL Ram air intake for a 95 Sunfire (https://www.pontiactalk.com/forum/sunfire-1995-2005-14/real-ram-air-intake-95-sunfire-7044/)
Dazed Oct 4, 2009 05:42 PM
I finally finished the ram air intake for my 95 Sunfire, using a hood scoops and a side grinder. The throttle body is front-ward facing unlike the Quad-4. So the scoop allows ample air to be sucked in the short custom intake, not only does it look good but the filter, throttle body and intake manifold are running alot cooler then the engine temp. This budget build up was a cost-effective alternate to the fiberglass hoods running around $300-$400. And the filter was wraped with a old plastic flower pot laying around the house. The IAT sensor is reading the right temp, I tried one of those sensor resistors claiming to help out the HP, but just made me run a little richer then I needed to. Check out the pics and let me know what kind of custom intakes you've made for your ride, I got tons of ideas for intakes so hit me up if you need ideas!!!
-David Diaz
