-   -   Trac Off light and shift problems (https://www.pontiactalk.com/forum/sunfire-1995-2005-14/trac-off-light-shift-problems-7535/)
Tristian Paul Jan 7, 2012 02:22 PM
Hi this is my first post, I'm a new used pontiac sunfire 2001 owner and I'd like to help and be helped.
Whenever I'm driving the Trac Off light will go on sometimes after 5 minutes other times after 20, after the light is on rpms will rise up to 4 thousand without shifting gears and when it shifts it kicks really hard. It has shut down 3 times but after a restart the light is off again.
Make: Pontiac
Model: Sunfire
Year: 2001
Engine: 2.2
I took scaned it at autozone and a transmission shop and the returned codes where the following:
P0122
P0420
P0742
In the transmission shop they told me that it might be the TCC Solenoid or a faulty computer, the cost for repairin the solenoid is $250 and for a faulty computer $200.
My question is if they're in the right path to solve the issue, or what do you recomend?
