79 T/A Electrical Problem
Old Jun 20, 2006 | 09:49 PM
nrider's Avatar
Default 79 T/A Electrical Problem
Hoping someone can help as aspiring mechanic with little experience. I took my '79 T/A out for a spin the other day. When I attempted to start the next day, I got nothing when I turned the key - no clicking of the starter, no interior lights, no electric to any part of the car. I had the battery load tested - in good shape there. I replaced the alternator - because it was suspect and only $32 for a remanufacturer one! I checked the ground - no problems there.
So, what else should I be checking? I am getting no juice to any part of the car and it happened all of a sudden! I am stumped! Could it be power to the starter? Fusable Link? Should I give up and take this to my local mechanic?
Any help would be greatly, grealy appreciated!
Attached is a pic of my nocturn blue bird.
[IMG]local://upfiles/391/E9846D4E70FC4FB093EB0657651C0F24.jpg[/IMG]
Old Aug 2, 2006 | 04:00 PM
Clint S's Avatar
Default RE: 79 T/A Electrical Problem
Bad ground. do you have a ground strap going frome frame to engine ? If not you are grounding through motor mount and that is not good enough
Old Mar 18, 2008 | 08:41 AM
firebird.77's Avatar
Make sure your power wires going to the starter aren't grounded on the starter body or frame.
drummerboy10189
Mar 13, 2013 11:34 AM
gath.trucking
Apr 6, 2011 04:50 PM
englishguy68
Dec 16, 2007 12:59 PM
vspadeasr
Aug 27, 2007 10:59 AM
laserlizard71
Jul 15, 2006 05:53 AM
