next question
a low coolant light keeps comming up in my 1994 firebird....i have added coolant, but only before i realized that there is a note on the engine stating that there is a certain way to add coolant, i hope i didnt f-up my firebird, please help....???
RE: next question
Normally you add coolant to the overflow tank. As long as you are using a 50/50 mix of coolant/water you should be ok, assuming you added it to the radiator itself. When you say the low coolant light keeps coming on do you mean it goes off after you add coolant and comes back on later? Is the system really low on coolant? If not, you may have a corroded or bad sensor. It is located in radiator below the filler neck. Disconnect the wiring to it, pull the flat U shaped clip that holds it in. Clean it good and put it back in. If it still trips the light and you are not low on coolant, replace the sensor. They are around $20.
