Bonneville While this model began its run as a full sized model, and shrunk down to a mid sized model in the 80s and 90s, it has returned to full size sedan status to be the flagship luxury model in the Pontiac lineup.
fuel problems?
Old Jun 15, 2007 | 08:17 PM
dougj4525's Avatar
Default fuel problems?
i have a 96 bonnenille that died on me the other day on the way to work, at 65mph it studdered a couple times then just died and wouldn't restart i took the intake off and removed approx. 1 quart of gas from it. when i took off the vacume line for the fuel pressure regulator it was full of fuel i scanned the codes and found it said cylinder 4 misfired. i have gotten it to run a little if i haol the gas pedal to the floor but it runs like it's only half running, very rough as soon as i let off it dies. i have had people tell me it's the cam sensor, head gasket, and a bad fuel injector, that's a pretty wide range of things to check. has anyone had a similar problem, or have any idea of what to check?
Old Aug 27, 2007 | 11:03 AM
PonchoFan's Avatar
Default RE: fuel problems?
I had a similar problemwith my '99 Bonneville SSEI, but my car was actually misfiring. I changed all the plugs and the wires and she purrs like a kitten. I used AC Delco plugs that I got from NAPA. They're worth it in my opinion.
lovemypontiac
Nov 10, 2011 07:58 AM
gmguy11
Feb 25, 2011 09:05 PM
revitup600
Apr 26, 2008 07:27 PM
teck
Nov 8, 2006 03:13 AM
evan55
Jul 24, 2006 08:04 PM
