-   -   cheap ignition key (https://www.pontiactalk.com/forum/front-wheel-drive-1988-2008-45/cheap-ignition-key-404/)
ventport Sep 6, 2006 03:01 PM
cheap ignition key
I went to the local GM dealer to get an extra key for my 2002 GP and the parts man said they were $63 each. Is there a place on the internet or somewhere else where they can be purchased more reasonably? Thanks Brian
Jeremy@fredbeans Sep 15, 2006 02:58 PM
RE: cheap ignition key
The part number is 88951932. Hopefully this helps you in your search for cheaper key.
ventport Sep 15, 2006 04:27 PM
Thanks for the reply. I was told that the key has a chip in it that is specific to my cars VIN # or is the key programed to my VIN#. In either case I still have to get it from GM and programed to my car at $63 each, am I correct? If not can you or someone clear this up for me? Brian
Jeremy@fredbeans Sep 15, 2006 04:31 PM
the programming procedure is simple....put the original key into the ignition and start the car...turn off the car....and within a few seconds....put in the new key and start the car....that's it. You can get it cheaper if you call this number 484-931-4800 they have discounts on parts and will ship it to you.
