-   -   Car Wont turn over all i get is clicking sound (https://www.pontiactalk.com/forum/grand-prix-16/car-wont-turn-over-all-i-get-clicking-sound-330/)
WhiteLightning Jul 6, 2006 10:26 PM
Hey my names Steve i just purchased a 96 Grand prix SE, one of the bulbs was out in my speeDometer so i went to go change it and in the process of trying to take out the gauge cluster i was unable to disconnect the wireharness from the bottom of it, then when i went to start the car wouldnt turn over, all i get is a clicking sound like the starter wont ignite the engine.... any help would be great to wer ei should start checking ... THANKS!
97GTP Oct 7, 2006 03:29 PM
RE: Car Wont turn over all i get is clicking sound
could just be the starter if it is only clicking.
shftn2gear Nov 9, 2006 11:00 AM
I had the same problem in my '04 Durango and it seemed to be the battery...jump started it and it ran but did it quite often and had to replace the battery
CornFed Mar 10, 2007 08:34 PM
That "clicking" is your starter solenoid doing it's job. My suggestion to you would be to check the battery.If the battery is okay checkfor a voltage draw. It's entirely possible that when messing with the instrument lights you mayhave opened a draw. This can be checked by turning off EVERYTHING in your car, disconnecting the negative batterycable, and attachingthe "alligator clip" part of a test lightto it. Then probe the negative terminal of the battery. If you get a light, you have a draw. If this is the case be prepared to spend some money. Also, are you getting any "battery/charging system" lights on your inst. cluster. A bad alternator may actually be draining your battery...this is an outside possibility.
Good luck friend,
-Thomas-
