-   -   Flipping a Car., (https://www.pontiactalk.com/forum/off-topic-6/flipping-car-1320/)
quinnquinn99 Jan 19, 2008 12:49 PM
Flipping a Car.,
Does anyone have a rough estimate of how much flipping a car from its side or just lifting a car from its front equivocates in dead lifting? I know flipping is a bit different but just lifting the front should be the same. I know people will be tempted to guess but please don't give an answer unless you are pretty sure it’s accurate. Thanks
marina meggy Jan 20, 2008 07:41 AM
RE: Flipping a Car.,
Hi, I really don’t have any idea about that, Cars all weigh different, have a different distribution of weight, and you will be lifting each car from a different height. Yes I can suggest you to have a look of some of car lifts. Nowadays Auto Body Lift is usually used and they are pretty helpful in such cases.
72blackbird Jan 31, 2008 08:52 AM
I wouldn't attempt it without a rotisserie- one of those welded tube-steel jigs that bolts to the body-mount points, has big casters on it so you can move it around the shop floor, and at least two more people to help you move it. They aren't cheap and usually only auto restorers use them- not a tool I'd think about owning unless I did that and had the room to use it.
Geno
