1st Generation 1967-1969 This section is for info pertaining to 1967 to 1969 Firebirds.
67 F-Body frame and body alignment points.
Old Jan 18, 2023 | 01:02 PM
Lake And Lodge Garage's Avatar
Default 67 F-Body frame and body alignment points.
I have recently started a 67 Firebird Convertible restomod project. In my research leading up to the build I found a lot of conflicting information on the body and frame alignment points used when replacing the floor and firewall system. When I started looking at the project I realized that my chassis, although requiring A LOT OF LOVE, was an example of a car that had never been hit or twisted. So I spent the time to go through it and measure every interesting point on the system and compared them to the factory supplied data, such as it is. I was interested in building my own assembly jig at the time and I really wanted to know more about the location of the rear mounting points of the front sub frame. I measured the points while the chassis was leveled on a lift then set up an auto twirler jig and dialed the points in exactly and remeasured every thing. I documented these points as closely as I could (+/- .1”ish). I would like to share this data to anyone interested in a similar endeavor. If you would like to have a look, you can find this data on my YouTube channel. https://www.youtube.com/channel/UC3f...wY853f2so5AvpA. Subscribe if you would like to keep up with the project and the challenges I run into. Also ping me if you would like and I will be happy to send you the PDF file so you can print it out. My email is listed on the channel under “About”. Of course I make no warrantee as to the accuracy of this data and you are free to use it at your own risk. Hope this helps you out.
Sparky480
Apr 5, 2021 01:27 AM
BlacktopYC
Member Group And Special Buys
Nov 19, 2020 08:00 PM
cjc5f9
Oct 1, 2008 10:58 PM
Tempest1
Apr 6, 2007 12:21 AM
WHOPPER
Jun 15, 2006 02:18 PM
