Sheet metal help.
Old Apr 23, 2021 | 11:07 AM
HVFDFIREFIGHTER's Avatar
Default Sheet metal help.
I took the rear seats out of the 80 firebird. Removed what was left of the seatbelt. Found a pretty good size home. I bought a new floor pan. Cut out the driver side rear seat pan. I can’t help but think there should be something else under the pan to connect to wheel wheel. But I don’t know what it is called. Any help?
Old Apr 23, 2021 | 11:10 AM
Would that be the inner wheel well tub? If so, can I put the tub on with out remove body from frame?
star bolts to remove seatbelts were a pain. Going to put hardened hex head in instead. I will need to weld the nut on to something, not sure what.
any help is always greatly appreciated!
Old Sep 4, 2021 | 02:32 AM
Photon440's Avatar
If you're going to weld the nut on, I'd fabricate a plate several inches square, of 1/8 plate to spread the load. You don't want the seatbelt mount to tear out when you need it most.
carid
Member Group And Special Buys
Dec 21, 2020 08:40 AM
franky0621
May 7, 2019 02:29 PM
glaranotch
Sep 24, 2008 12:54 PM
oceancon
Sep 2, 2007 09:52 AM
getaforknjob
Jul 31, 2007 05:38 PM
